Yota conversion question
cruznlow612
I am in the process of doing a 5 lug conversion and i was wondering if i will need the toyota drop spindles in order to lay out on 20's in the front? thanks
Kyle
twisted minis's avatar
twisted minis
You don't want to use a whole Toyota spindle, it will create bump steer because of improper suspension geometry. Your best bet would be to get a 5 lug hub. I think the spindle can be machined to the same taper as a Toyota and run a Toyota hub and disc, and space the caliper correctly, then you will have no steering problems.
Or, there is a guy in Canada machining Mazda 5 lug hubs from scratch that comes with a disc that fits with the stock caliper, and provides a little extra offset.
madmazda
Who's this guy in canada?...
twisted minis
He goes by ToyBoy89 on SSM. Hes in White Rock, BC.
I'm pretty sure it was him making the hubs.
