Mazda Lowering Static \  Camber....
Camber....
views 792
replies 4
following 5
watt   +1y
I just wanted to know how much its usually runs to get a alignment and fix the camber after lowering the front about 3 inches by crankin the torsions...also is it the older isuzu p'up shocks that are about 2 inches shorter that some of you guys run?
b22bmber   +1y
not much...around here u can get it done for less than 50 bucks
90-b22dawg [andrew]   +1y
its easy to do a self alignment if you have general knowledge of the machanics of the vehicles suspension. i used metal shims on the top control arms to correct the camber i got when i lowered my truck with the torsion bars. it was fairly easy, only took me about 30 mins per side and only $7 for shims. but usually a good alignment shop should charge around $50.
apollos84   +1y
I did the same for my nissan pickup it has torsions. If you decide to adjust your camber
I put a level against the tire and shim behind the control arms till it level or close to it.
twisted minis   +1y
If you do it yourself I wouldn't use a level. I'd use an angle finder. You generally want about -1 or -2 degrees at ride height, on average. With -2 being on the aggressive side. Alignments here go for $65 about.
