Mazda Lowering Static \  ok here goes
ok here goes
views 732
replies 6
following 5
mazda_speed87   +1y
i have a 3in block in the back now if i pull the middle leaf spring and leave the one for the e-break bracket and the main spring with the overload how much of a drop will that be with the 3 in block??
mazdawg(mikey)   +1y
if you only remove one it wont be that much of a drop. if you take them all out and just leave the main one and put the overload on top, it will be a major drop. enough to put the frame on the rearend. then you just need air shocks for alittle adjustability.
87mazdamini   +1y
leave the overload onthe bottom where it goes so your main leaf doesn't snap or twist on you.
mazdawg(mikey)   +1y
the main leaf will not snap or twist as long as the overload is kept....either top or bottom.
nascarguy3   +1y
I have been running the main spring only for 2 years now and I drive the shit out of it with no problems..
toddluck   +1y
this is stock
this is with only the maun spring
you DO need the overload on bottom or you get axle wrap and a very harsh ride
toddluck   +1y
sorry i forgot to mention the second pic is with a one inch block
