Mazda Lowering Static \  switch hits
switch hits
views 650
replies 4
mazda23   +1y
my set up is... 7 gallon tank, 380 viair compressor, 175/145 pressure switch, 1/2" line valves and slam bags. i just finished baggin it today and i only get about 2 hits of the switches before the compressor kicks in. what would be the best thing to do: get an adjustable switch, buy another compressor so it fills quicker, or wut else would be a good sugestion??
Post was last edited on Oct 29, 2007 02:10. This post has been edited 1 times.
v8mazda4ever   +1y
If you want to hit switches for a long period of time you will want to go with a scuba tank or some other contianer that will hold an extreme amount of air at alot higher psi but you would need a regulator to use with it. I am going with 2 scuba tanks they hold 3000psi of air and with a 200 psi regulator I will be able to hit the switches for a lot longer at shows or even at the saturday night car show.
elbine69   +1y
Get bigger compressors, An engine driven compressor or scuba tanks. You could go with a 5 gallon tank also, less volume, but faster recovery times.
solow93 (ryan)   +1y
go big I got a 12 gallon tank and it last very long plus I run a engine driven
mazda23   +1y
ive been doing some searching on the website about edc. What do i look for since i read that mazdas came with different model pumps and what would one of these run for at a junk yard. I looked at my engine block today and i see some tapped holes on the block, so does this mean that my truck already has mounting holes for the pump. some pics would be great
