Mazda Lowering Static \  i need to get lower lol
views 881
replies 6
following 5
draggin4life   +1y
i have a 92 b2200 i cranked down the torsion in front and i put 3in. blocks in the back. my question is its sitting at about a 1in. rake and i was told that if i take out the 2 center leafs on both sides that it will lower the back the extra 1in. i need and i still have about 3in. of clearence from the rear bumpstop and the frame so i should have enough room well does anyone have any input on this.??
zenkifc3   +1y
if u pull out those leafs... it will more than likely go lower than an inch.. when i did it to mine it lowered almost 3in. extra... ull need to shave, or remove the bump stops, and there is a possibility that u will bang the axle on the frame on hard bumps... i just bought the belltech 3in monoleafs, and i dont have a problem bottoming out the back anymore.... make sure u get drop shocks cause those will bottom out eventually to... well... depending how low u go... i went really low lol...
mazdagurl   +1y
well if you take out the two center leafs you will drop it about another 1.5 to 2 inches but definately more than 1 inch
draggin4life   +1y
thanks guys i just want to get closer to the ground i cant wait to bag it lol
mr.bbs   +1y
did you end up removing the 2 center leafs?
draggin4life   +1y
yeah i removered the rear bumps and shaved down the front ones and removed the 2 center leafs on both sides and it sits low and even and not to much bottoming out. thanks for all ur info
1lob2k   +1y
Both sets of my bumps are gone, NO torsions up front. Out back I have 3"blocks, with just the one leaf remaining, not even the over load. I know somone will say that I shouldn't have done that, and they are right, that's why I got mine that way. The truck does bottom out pretty DAMN hard, but I'm getting ready to bag the truck hopefully. When I do get it bagged, I will try to post up some pics.
