Mazda Lowering Static \  bagin it
bagin it
views 1302
replies 14
following 9
draggin4life   +1y
hey i am starting to buy stuff to bag my truck and i only want front up and down and back up and down thats all so i only need 4 valves right? any help?
devb22   +1y
Yes...
Hit me up @
I've got SMC 3/8" Valves on sale for $28/each
Devon
v8mazda4ever   +1y
well in some ways you are right but honestly to have a better ride and a safer ride you want 8 valves and only like 4 switches maybe 6 if you just want up down no side to side.. The reason for this is if you only have 4 valves you will get alot of body roll when turning corners and this is from the air in the bags moving from bag to bag if you have 8 valves you have each bag self contained and you will limit body roll and have a smoother ride.
speedster93b   +1y
v8 is 100% right. get 8 valves. you can still wire up just front back but you want that stability
draggin4life   +1y
thanks guys
87mazdamini   +1y
Can't you just run a check valve?
devb22   +1y
Couldn't you run a 6 Valve setup to reduce this problem?
Dev
twisted minis   +1y
Yes, but the back will still roll a bit.
speedster93b   +1y
i didn't want to mention only running 6. but yeah you could.
hmm check valves... that would work too. run the T then checkvalve then bag... yes i think that'd work.
up2nogood   +1y
Would the check valve idea really work? I'm in the middle of planning a system, it would be a bit cheaper to only have to buy 4 valves.
