Mazda Lowering Static \  DOES ANYONE KNOW THE LARGEST OFFSET FOR A 92 B2200
views 2661
replies 10
following 5
waytolow   +1y
well i have a 92 b2200 i want to lay frame on 20's does anyone know what offset i need to be able to tuck that twenty in the wheel well.
dropped90(justin)   +1y
how wide of a rim are you plannin on running?
-justin
waytolow   +1y
i plan on getting 20x8.5 with a 245/30/20 a little bit more choices with an 8.5.
nate   +1y
you'll need at least a +38mm offsett and still need 4wd fenders to clear good..
nate   +1y
hrere are some pics of a guys truck that has 20x8.5 KMC Dime with a +38mm offsett
waytolow   +1y
thanks man you were tons of help one more thing though whats the biggest offset i can go with out any problems i want to be able to make slight turns while slammed any info would be greatly appreciated.
speedster93b   +1y
remember you'll have camber gain. if your not bodydropped you'll be able to turn a little if you can tuck 'em
waytolow   +1y
thanks alot for your help.
speedster93b   +1y
do u know that guy? how many inches is the tire bulge from the fender? is it bagged or what?
redflash   +1y
Nate posted those pics for me. That is my truck i just didnt have time to post yet. As of right now it is not bagged just staic droped all the way. It has no tire bulge, the tires are 235/30 20 nitto neo gen tires. I did have to raise the front up 1/2 inch off of the shocks so the tires dont rub the fenders. I do have 4x4 fender on the front now and they do not even come close to rubbing. With 4x4 sheet metal all the way around they will not rub if bagged. By the way the wheels are 20x8.5 KMC Dimes 100 center bore with a +38 offset.
