Mazda Lowering Static \  any suggestions on baggin the front ofmy b2600
views 1119
replies 12
following 7
bgdb26k   +1y
hey guys i am going to bag my b2600, what are my options for the front other than buying new control arms?
any info will be greatly appreciated
thanks
N8
<img src="{SMILIES_PATH}/icon_question.gif" alt=":?:" title="Question" />
dropped90(justin)   +1y
what size rims are you running? you can lay out on modified stock suspension parts up to 18&quot;
-justin
bgdb26k   +1y
i think i am just gonna roll some escalade wheels for now
you can lay out with the stock suspension stuff then
-justin
bgdb26k   +1y
ok thanks. then if i wanted to go bigger than 18s i would need to buy new control arms right?
no you could just buy some 2 inch drop spindles and be good.
-justin
roger26i   +1y
if you run anything bigger than a 6 inch bag youll have to drop the sway bar down about an inch for clearance and cut off all bump stop brackets
bgdb26k   +1y
thanks guys, you rock!!!!
v8mazda4ever   +1y
actually you can lay out on eskies with stock parts but I would suggest getting drop spindles if you want your rubber to last as with stock spindles you will get some serious tire wear camber will be a definite issue if you don't cid has been driving his truck fully aired for 3 months and his tires still look mint no wear other than regular use.
speedster93b   +1y
depends how low u drive. you can lower your truck and get it realigned, they'll fix your cambercaster and toe at a new lower altitude, and then your golden. or save your tires and air up the front a couple inches. simple.
