Mazda Lowering Static \  Screw-In Ball Joints
views 699
replies 5
following 2
devb22   +1y
I am looking for some screw in balljoints, something like an S10 style...I think...something similar to a uni-ball in that it will get 30 degrees more travel..
Any info would be greatly appreciated!
Dev
twisted minis   +1y
Moog PN K772. You will have to ream your spindle taper for it to work.
devb22   +1y
That is the part number for the upper correct? Could you use a screw in type for lower ball joint? Lets say for a tubular arm?
So I just need to pick up a balljoint reamer then...
I saw those bj on speedwaymotors site...
Dev
devb22   +1y
Im thinking I might just use a screw in s10 style ball joint since the mazda drop spindles already come with a lower s10 ball joint...I would still need to get them re-tapered though...
What about Howe Racing Precision ball joints...they offer an screw in that interchanges with a Moog P/N K772 and looks like it gets 32.25* rang of motion..
Hmmm?
Dev
twisted minis   +1y
Yes that is a part number. You can pick them up locally.
Lower screw in PN is K727, also Moog. That one you need a different reamer for.
devb22   +1y
Well I knew it was a part number... Just wanted to make sure it was the upper!
I will check it out tomorrow...
Thanks,
Dev
