Mazda Lowering Static \  is it safe?
is it safe?
views 1236
replies 13
following 9
2_fckn_lo   +1y
is it safe to pull the torsion bars out with out baggin?i know u pull em when u bag and shit i was just wonderin
toddluck   +1y
you can pull them i wouldnt very bad ride but yo can reindex them so they dont drag the bracket
v8mazda4ever   +1y
I wouldn't pull them until you are ready to bag bro. one you will be on your bump stops and it will drive like a hay wagon. second to me iot is unsafe and third it will destroy your rubber bro way serious camber issues.
kirk   +1y
No. Hows that?
crazymikey   +1y
You can,and then we'll just say we told you so.
deviousb2200   +1y
I can tell you from experience DO NOT pull them until you wanna bag it... I was on a quest to be as low as I could go... I took em out and took out all my bump stops.. It rides like total CRAP.. it will bounce you around like crazy... You will be tuckin tire if your on stock rims with stock size tires it looks killer but like they said you will have camber issues.. I went through a decent set of tires pretty fast was starting to show metal.. If you wanna go low take em out if you dont mind a bad ride and chewing up tires.. If you dont then do like they said and reindex your bars and go low
crazymikey   +1y
just put drop spindles on it and crank the torsions down. My front crossmember was only about 1.25" - 1.5" from the ground.
Mine's pretty low in the front and it rides really nice. Best part with the spindles is straight alignment and no camber issues.
carolinasled   +1y
I should have some drop spindles for sale this weekend.
2_fckn_lo   +1y
riding like crap dont really bother me
roger26i   +1y
hell i have rode without them for 6 years or so just have to keep tires rotated alot and it will b fine just bumpy as hell
