anyone notch their lower control arms?
maz
If so anyone have any pics? I think I finally found my problem, I flipped the upper ball joints,
pie cut the uppercontrol arms, still wouldn't go all the way down
next took out the bags, still stuck, took off sway bar and radius bars still hung up so all that leaves is the lower control arm am I correct?
Thanks
Jamie
trashed's avatar
trashed
the lca HAS to be notched if you want to lay on any size wheel/tire.
dropped90(justin)'s avatar
dropped90(justin)
check out the tech write up for how to bag the front of a mazda and there is a picture in there showing the correct area to notch the lowers
-justin
maz
Thanks for the quick responses, people have said you do and don't have to notch it, Ithink it depends on the truck
Thanks
elbine69's avatar
elbine69
It depends on what size wheels your running, and if your running drop spindles or not.
crazymikey's avatar
crazymikey
All you do is basically cut out the little hump in the LCA. It's pretty simple. 5 minute job per side. It has to be cut if your balljoints are flipped because they won't fit properly if you don't notch it.
check out bscene bandit bitches in the project thread i have some there
