Rear Disk brakes?
drtracer14@msn.com's avatar
Rear Disk brakes?
dirtracer14's avatar
dirtracer14
Does anyone have them? I did some research today at the parts store and came up with a few ideas? I want to keep the 6 lug...the 5 lug stuff is peice of cake
Post was last edited on Jan 04, 2008 04:41. Edited 2 times.
baggedb22
I do but i am running a Mustang 8.8 rear...
jmzcustomz (jeff)'s avatar
jmzcustomz (jeff)
I would like to eventually.
mazdamn's avatar
mazdamn
isuzu rear, or a toyota 4wd rear. Some models/years had rear disc.
pont's avatar
pont
You can use the front disk rotors from a Chevy 4x4 the older ones (late 90's) and hone out the center hole and fab up some brackets for the calibers
dragginmazda86 (dave)
^^ I helped with my buddys 82 fullsize blazer he bought the rotors as stated above i fabbed up so brackets and we used the floating style caliper of say off a 79 monte carlo. You might be able to try that might look a little awkward the rear rotors will be larger than the fronts.
pont's avatar
pont
One other thing I don't think that you can run the stock 14 inch wheels cause of the size of the rotor and caliper.
baggedb22
Yeap my rear rotors are just alittle bigger then the stock front mazda rotors. But stopping is sooooo much better..
nytrdr24's avatar
nytrdr24
I have an 85 rx-7 rear in mine with disc, they are about the same size as the front, and the calipers have the hookup for the e-brake cables...there are a few pics in this thread
but as you said you want to keep the 6 lug, your options are a little different, keep the stock axle, and adapt the chevy rotors & such to work, or a late 80's-95ish toyota 4wd rear is the same width as ours, and downey offroad sells a kit that is pretty much what the guys were talkin about above, chevy rotors, monte carlo calipers, and a bracket....the upside to the yota axle is there are several different gearsets, and you can get lsd or a locker for them, whereas the stock mazda axle has only one gear offering, and no lsd or locker.
V
v8mazda4ever
I used the nissan pathfinder rear end out of a 94 comes with the discs and it fit right in and is 1 or 2 inches smaller than the stock rear end.
