Mazda Lowering Static \  91 b2200i air suspension help
views 703
replies 3
matrixbackman01   +1y
stock 91 b2200i 5spd std cab with A/C
I ONLY WANT TO LAY FRAME as this truck will be a semi-daily driver and i already have a bd'd fullsize
wheels - 2 options here
1) factory mazda's w/ 205/70/14 25.3" dia
2) 18*8 5"BS +12mm offset w/ 215/45/18 25.6" dia
rear - i already have a 521 rear end that i plan to swap into this truck and if i'm not mistaken the 521 rear is about 4" narrower than the factory mazda so that takes care of clearance issues with the bedsides.
onto the front (heres where i really need some info as i'm a fullsize chevy guy) I would like to run tubular uppers and lowers, is there anybody else that makes them other than Cando?
1) can i lay frame on an almost 26" tall tire with minimal firewall/clutch/booster work?
2) since my rear end is about 4" narrower than stock is there any way i can narrow the front to somewhat match?
framedragger2   +1y
theres a few companys that sell the tubular arms, but you really dont need em to lay out, if your only gonna lay frame and bd it the firewall, booster, etc. shouldnt be a prob.as far as narrowing the frontend to match the rear, with only 2'' on each side, i really dont see it that much, but if you do want to do the front, get ready for a lot of work.
elbine69   +1y
This guy narrowed his frame quite a bit so he could run 24's all around.
dropped90(justin)   +1y
wassup man im in hickory.
-justin
