please help controll arms?
8
8083tcman
i bought a 88 isuzu pickup already bagged it has 17 inch escalades on it and is close to laying frame but i want it to lay frame what do i need to do a friend told me i can notch the control arms is this safe ? will it work let me know thanks for the help
eatinpavement's avatar
eatinpavement
i wouldnt think you would have to notch the control arms on 17s. are you sure the bag isnt holding you up? is it compressed all the way?
low_pup
you got drop spindles? mine lays just fine on 17" escalades with 40 serise tiers. i even had my wheelwells. no notching dont to my LCA's
8
8083tcman
should i raise the bag brackets? because the bags are all the way compressed and its not laying and my fender is all cut out it seems like my controll arms are banging on the frame let me know what you guys think
I
isuzueh
what size tires are you running on those wheels
8
8083tcman
205/40 r17
sicpupidaho's avatar
sicpupidaho
do you have drop spindels? im on 18s and layed out before my bodydrop.
low_pup
yeah, if you cant layout and your LCA's are on the frame then you need go go buy some DROP SPINLES.
8
8083tcman
im thinking i have them because i have no camber on those wheels let me know if i should still buy some or how i can tell whats the difference with the stock ones
dhpmike's avatar
dhpmike
you can notch the lowers and have the balljoint angle flat meaning that its level from the bushings out to the balljoint and you should be able to lay a large wheel on stock spindles.
Related Discussions in Suspension
