Mazda Lowering Static \  cando arms
cando arms
views 766
replies 7
following 5
hybrid   +1y
ok, im installing my lower cando arms and i got the bushing out just fine. but there is a metal insert that needs to come out, and i cant get it out. i tried pressing it out and punching it out and no luck.i know i have seen a thread about this before but cant find it. any advice?
ben thorne   +1y
Just heat it up with the gas axe man. Thats what i did. Just have to be carefull.
speedster93b   +1y
gas axe? interesting...
if you can't press it out i don't know what to tell ya.... except try what ben said... heat it up
hybrid   +1y
i was also told by seth and a couple other to use a sawzall and make a few cuts on the inside and punch it out.so im going to go buy a sawzall(my tools were stolen) and try it since it seems to be the most effective
devb22   +1y
Still waiting on my arms....Ugh!
Dev
hybrid   +1y
yea it took about 2 months for mine to finally come in.but i wasnt in a hurry cause i was still building the frame
bikerider   +1y
if you can get a welder in to it run a beed of weld thru it when it cools it will shink a bit and should tap out
hybrid   +1y
i got it with a sawzall,two cuts and it punched right out.very easy.i just sent my arms off to be powder coated
