Mazda Lowering Static \  yoda hubs?
yoda hubs?
views 590
replies 2
blackhulk   +1y
can u use a yoda hub like form mid 80's to 90's and the yoda bearing to fit over the aim spindles or does any machining have to be done..i try to find something long these lines on other posts but cant find any so i have to ask...thanks man
badchicn (rick)   +1y
I believe Yota hubs are longer than Mazda spindles. You need to change the complete spindle/ hub assebly. IMO better to redrill the stock hub.
dropitforme   +1y
if you look around i belive there is a post that talks about those years of yota spindles rather then just the hub and if i remember right if you adapt a yota lower ball joint to the lower mazda contol arm you can use yota spindles on a mazda
