Mazda Lowering Static \  How high of a Notch.
views 562
replies 2
frogg   +1y
I want to run 18*7s with a 215/35/08 tire. I want the step notch to be as low as possible. how far into the frame will i need to go. Some pics will be awesome...either on here or email me at
dropped90(justin)   +1y
the best way to do it would be to bottom the axle out to the frame and then measure from the bottom of the frame to the ground under the cab and thats how high you need the notch. always good to leave a little extra incase you go bigger eventually.
-justin
devb22   +1y
I have an 8" Notch and running an 18X8 Wheel w/ 225/35R/18 Tire
I have approx 2-3" before I bottom out the notch...
Hope this helps?
Dev
