Mazda Lowering Static \  finishing bagging the front and have a question
views 600
replies 7
following 6
3rdtimesacharm   +1y
im finnishing up bagging the front end and i was wondering what to do with the brake line? should i mount it or just let it hang?
devb22   +1y
I would at least try to re-mount it, but if not then zip-tie it up out of the way?
Just use common sense!
Dev
twisted minis   +1y
14 gauge sheetmetal mount that hangs off the side of the frame.
3rdtimesacharm   +1y
i have it all conected but between the frame and caliper is my concern im worried that it will rub the bag.
cidawg(taylor)   +1y
if it is a mazda there should have been a braket on the inside upper A arm that you can weld on the outside front of the arm. Run the brake line under the top of the spindle next to the upper balljoint nut. I've owned four mazdas that I did this way and it stays clear of the bag and wont hit the tire.
audioinmotioninc   +1y
i have my brake line routed the same was as cidawg and it gives clearance and wont rub the bag or tire or anything else for that matter.
mazda23   +1y
same here i have mine the way cidawg and audioinmotioninc and it works really good
3rdtimesacharm   +1y
thanks alot i will do that today!!
