Mazda Lowering Static \  axel wrap
axel wrap
views 957
replies 15
following 6
effdbmx1   +1y
what exactly is it? and what does it do? i'm driving 1000 miles down to LA this weekend and i remembered people mentioning it. will it affect my trip?
twisted minis   +1y
When the axle twists with the wheels due to excess leverage against the leaf springs.
pepehn   +1y
you'll be fine.
from thunder bay, with 4" blocks i drove to....
winnipeg,MB (800km)
sudbury,ON (1000km) x3
duluth,MN (400km) x5
i think it is really only present when your accelerating, if your at a constant speed you should be cool.
pinion angle and all the rest of it are a different story
effdbmx1   +1y
so i shouldn't accelerate as fast as i can? and my blocks aren't angled, they are just flat.
effdbmx1   +1y
and what happens to the axel when it twists?
framedragger2   +1y
your pinnion trys to point up. an with a 4'' block you should really concider gettin angled shims to correct that pinnion
effdbmx1   +1y
no i have a 3" block, pepehn had a 4
framedragger2   +1y
oh my bad
layedoutb2k (chase)   +1y
your axle twists and causes u-joint bind. if it binds hard enough it'll break. i dont think a mazda motor even has enough power to worry about it too much as long as you arent like droppin the clutch real excessively.
effdbmx1   +1y
damn. my current wheel diameter is bigger than stock so i kinda have to accelerate harder to be the same speed.
