what does everybody do with this stuff when bagging
draggn97civic@hotmail.com's avatar
outkastdawg's avatar
outkastdawg
rear tank mount
another of rear tank mount
1990b26akathebeast
i removed it all and havent had any problems, but im pretty sure you will loose your abs.
layedoutb2k (chase)'s avatar
layedoutb2k (chase)
i moved my tank mount up and mounted it on the notch to keep the tank from dragging. never had that piece on any of my mazdas in the third pic.
fanninator's avatar
fanninator
not to jump off topic but i love the cowl hood on your ava 1990b26akathebeast, its yours i assume? -bf
outkastdawg
well my abs is unhooked under the hood and i dont really care for it anyway so that wont be a problem loosing it and there is a sensor on the rear end that isnt hooked up but there are wires that i guess go to it cause thats the only empty plug back there
1990b26akathebeast
yeah im the same way i hate ABS. just pull that off and run a new solid brake line.
-and yeah thats my hood, i apreciate the compliment since most people hate it.
outkastdawg
so basically just tap my main line into the line that runs into each wheel
nytrdr24's avatar
nytrdr24
as said before, the piece behind the axle is for the abs, there is a wire that goes to it, one on the axle carrier for a speed sensor, and then the abs control unit under the drivers seat....you said something about a wire under the hood? there is one that hooks to the master cylinder that is for the fluid level, which will light up the brake warning light if it goes too low with fluid...., not sure if with the abs stuff unhooked that if you leave the one for the fluid level hooked up that the warning light won't come on because of the abs stuff unhooked....
as you said, you could just make a hose and tie the hard line on the frame to the passenger wheel cylinder on the axle, and be alright..
outkastdawg
under the hood i was talking about the metal lines were unhooked cause the guy i got it from couldnt get the right front to bleed and when he bypassed the abs stuff he got it to bleed
