Mazda Lowering Static \  help question on the rear end
views 604
replies 4
following 2
93mazdab2600   +1y
i have a question about the sensor that plugs into the rear end do i need it can i just unplug it and just eliminate it what does the sensor do and by the way the truck is a 93 b2600i and also i have a question about the brake likes on the rear end what did you guys do with them i had ABS but i eliminated it and now my lines are jsut hanging there so i was wondering if you guys had any pics of what you did with the back passenger side brake lines i just want to make sure the first time i raiose or lower the truck its not going to bend are kink the brake lines thanks guys fr the help i really appreciate it
outkastdawg   +1y
i was told the sensor was a speed sensor for the abs and if you have removed your abs just unplug it mine is unplugged and it doesnt affect it
93mazdab2600   +1y
well i was wanting to make sure before i eliminated it and be sure it didnt effect anything so i guess i will eliminate it it doesnt mess with you speedometer or your rpm gauge
outkastdawg   +1y
your rpm runs of you its either your coil or distributor and your speedometer runs off your tranny
93mazdab2600   +1y
ok so i will just eliminate it than thanks
