Mazda Lowering Static \  knocking squeaking and banging...
views 666
replies 6
b22low   +1y
ive had my truck lowered for a couple of months now i dearched my leafs and put 2 inch blocks in. in the front i originally cranked my torsions and after 2 months i decided to re index them instead ive been ridining around wiht them reindexed for about 3 weeks now and im starting to hear this knock or clank from the passenger side in the front. im running stock chrome stealies and 205 tires. what is it?? thnks for your help
airedout89   +1y
Lift the front wheels off the ground. On your passenger wheel grab the top and bottom and see if it wiggles. If it does then you need new bearings.
b22low   +1y
would you hear that when coasting speeding up it would get loud and slowing down it would get quieter??????
airedout89   +1y
Mine is doin the same thing. When I changed my brakes the other day I checked to see if there was any vertical movement and there was. Which means it is time for new bearings.
b22low   +1y
ya i dont have any groaning when coasting which is what make me think that its not the bearing
sonikk71   +1y
How low are you in the front and do you have shortened shocks in the front? I know when I first lowered my dawg really low I didn't have the cash for toxics and I had cut out the bumpstop mounts. Turns out it was sitting on the factory shocks and after awhile it started making some noise. Just a thought...
