Mazda Lowering Static \  Fitting FJ Cruiser rims
views 1271
replies 5
stww1fa   +1y
I think this is my first post here (but registered and been searching/looking around for a month or so). Great site and info!
Anyways, I've found a deal on the 2007 FJ Cruiser wheels (the polished version).
The size from what I can find seems to be 17x7.5 with 15mm offset.
If these work, what size tires to use? Will these work without sticking out? Rubbing issues?
I'm not looking to tuck these as of now.... Just trying to spruce up the look with a static drop (torsion bar reindex and 3" drop spacers in the rear). My truck is a '92 2wd pretty much stock.
Thanks much.
dropped90(justin)   +1y
any pics of the rims? i think i know exactly what they look like but just makin sure.
--justin
stww1fa   +1y
Here's a pic of the rim.
And also to an eBay auction of the same rims:
Thanks!
90-b22dawg [andrew]   +1y
those look tight.... shouldn't have any problem with fitment
stww1fa   +1y
Thanks, B22Dawg. I'll look into getting them.
Maybe once I get them outfitted, it'll be worth setting up my account with some pics
Of course, it'll look almost like your ride. I've pretty much got the same truck (and color), but without the extended cab.
sonikk71   +1y
So that wheel is a 7.5 wide with a 4 7/8" backspace... If you are not trying to tuckvery far on 2WD sheetmetal you should be fine. I would run a 215/45/17 if you want a tire that is about the same size width witha little height or a 205/40/17 if you wanna be a little stretched.
