bump stops????
banjoguy27@aol.com's avatar
bump stops????
89mazdawg(daniel)'s avatar
89mazdawg(daniel)
is there any other way to get the back bump stops out besides cutting them out? can you pry them out with a screw driver or some other way? and where exactly are the bolts to crank down the torsions up front, i'm looking to lower my truck here within the next few weeks.
take loose your ubolts and just remove them when you add blocks o the rear you will have to remove the stock ubolts anyways...in the front the tbolts are right under your seats next to the tranny....just follow the brrs from your control arms to the end of the bar find the bolt and loosen them ....equally
snoplow
what he said^^^^^^^^^^^^^^^
dropped90(justin)'s avatar
dropped90(justin)
^^^^^what they said
-justin
badchicn (rick)'s avatar
badchicn (rick)
What they said!, but I always take a hack saw to mine just above the top of the u-bolts. That way you get the maximum travel and you dont get that annoying clank when the rear hits the frame. (only matters on a truck with no notch.) I even put Mazda bumpstops cut like this on my Toyotas and Nissans. (over the years I have had a lot of static dropped minis.)
8
88b22
X2...i took out 2 leafs and 3" blocked the rear of mine and i just bought some gabriel air shocks and eliminated almost 100% of axle frame contact...
