Mazda Lowering Static \  torsion bar
torsion bar
views 728
replies 7
following 5
1lowb2200   +1y
well guess what peeps as a true do it ur selfer i was trying to crank down the torsion bars today to sit the front down and guess what happened................... thats wright i broke the bolt that u crank down the torsion bars lol so the driver side is sitting way down now i do have a question can i still drive the truck, turning and stuff, with the torsion bars out, the ball joints flipped and it sitting on the factory chromes pls help lol
thebeaumartin   +1y
it will be a nasty ride with lots of rubbing and bumps but if you had to you could.
1lowb2200   +1y
so it would probably be better to get another bolt to put the torsion bar back up?
thebeaumartin   +1y
thats what i would do
hex0rz   +1y
Make sure the BOLT IS GRADE 8 or HIGHER!
As well, did you try doing this without the truck jacked up?
toddluck   +1y
yes you can drive but its gonna kill your kidneys just replace the bolt
90-b22dawg [andrew]   +1y
always ALWAYS!!! jack the truck up befor turning the torsion bolts.... and do not DO NOT use an impact or air ratchet.... always use a manual ratchet
1lowb2200   +1y
ok thx guys for all the input but to answer ur question about if i jacked it up .....................nope lol i guess thats what i get for dropping dimes and not dawgs im just not use to the hole torsion bar thing lol but at least my bro has got a parts dawg i can get what i need from lol and nope i didnt use the impact or air ratchet cause it makes it harder to get both side the same lol so atleast i did that much right lol i will post some pics i took of the broken bolt and the truck after it happened lol man she sits low
