Help w/ Wiring for solenoid block, digi gauge
mannythis@yahoo.com's avatar
usmcperez's avatar
usmcperez
I'm re-plumbing my truck with a fresh set of SMC valves from Suicide Doors
and I'm having issues wiring up 2 new 480 ViAir compressors a starter solenoid (instead of using 2 relays).
Unsure what wires go to each of the 4 prongs off the solenoid.
Last I checked only 2 or 3 of the prongs were needed, but it's been a while.
Also, i have a Dakota digital gauge that I believe was also hooked up to the pressure switch somehow. I also have a 7 switch rocker controller from AVS.
Any and all help is appreciated in advance guys,
thanks
devb22's avatar
devb22
I would run the relay's imo!
Using a starter solenoid will VOID the warranty from what I am told!
Just my two cents!
As for the AVS Rocker Box....Should be something like this:
Top Left = Left Front Up/Down
Top Center = Front (Left/Right) Up/Down
Top Right = Right Front Up/Down
Center = All Up/Down
Bottom Left = Left Rear UP/Down
Bottom Center = Rear (Left/Right) Up/Down
Bottom Right = Right Rear Up/Down
Dev
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
usmcperez's avatar
usmcperez
Thanks for that Dev, I've ran this type of setup before without any problems, I'm sure I can figure it out.
usmcperez's avatar
usmcperez
B22, I owe ya a beer, but how would this look if i am running the batteries in parallel?
The rear battery is hooked up to the front battery (for charging).
I'm thinking the right side of the solenoid goes to the compressors, then the center prong goes to the pressure switch,...right?
