Mazda Lowering Static \  layin frame with 18s
views 682
replies 7
following 6
lvnlo   +1y
can i lay frame with 18s without drop spindles? just wanna know before i cut or dont cut more out of my lower control arms
At the mo it's sitting bout 1 1/2 inches of ground, flipped lower ball joint and cut out some of inside lower control arm
Just trying not to do more cutting than i have to
Also should i plate up front were upper bag mount is going to make stronger???
thanks guys
mike
at dusk   +1y
well on my 73 i dont need drop spindles.. i can lay out on 20s ( if my fenders were large enough with the body drop.. all i can run are 18s with 215 35 18 rubber to avoid comming through my hood..
hex0rz   +1y
YES AND YES!
elbine69   +1y
^I concur with him.
pimpeasyelil   +1y
i concur x2
sik and twisted   +1y
You can make it lay on 18s.On my old mazda i had put an 18 with a 35 series tire and it layed the only thing was that it rubbed on my firewall but it was bodydropped so you shouldent have that problem
lvnlo   +1y
thanks guys, i thought that would be the answer, just trying to not make more work for myself
hex0rz   +1y
Well, you can do 18's but it all depends on offset as well and how wide the rims are!
