Mazda Lowering Static \  help me get lower and lay out the front.
views 715
replies 7
pimpeasyelil   +1y
I finished baggin my truck and the back lays out fine. The front seems to be an inch or two from layin crossmemeber.
I have pathfinders with lo pros so no rubbing. Also I have flipped ball joints and notched lower arm. I was thinking it could be because my upper bracket isn't angled up but I am unsure. Any one have any feed back or suggestions.
I thought i had read a thread about this awhile ago but I can't find it. Help me slam the shit out of this thing.
E
elbine69   +1y
Your upper bracket could be too low. You could take the bag out and jack up the wheel to see if it would lay out then. If it is to low you will probably end up having to notch the lower arm more.
pimpeasyelil   +1y
i think they were pretty high up on the frame rail. however they were straight and not angled up. Any other things you can think of? I notched the hell out of my lower arm. Pics are in my project thread.
E
elbine69   +1y
Angling those up looks like it will gain you quite a bit.
pimpeasyelil   +1y
You think it will gain me enough to lay out. Any other things I should look out for.
E
toddluck   +1y
remove the bag and see if it lays
v8mazda4ever   +1y
Ya as toddluck says take out the bag and let it down and if it lays out then remove your upper mount and put a plug in the bag deflated and remount the upper bag mount. If you are going to use bigger wheels then if you have not already put drop spindles in I have a set ready to go that now that my son has decided to do up the nissan the drop spindles must go.
pimpeasyelil   +1y
Thanks guys I will try to this in the next couple weeks. V8mazda how much you want for the drop spindles??
E
