best way too set up bag bracket up front
slamedb22
whats the way everyone doin too figure out were at on frame to mount upper bracket up front im tryin too figure out how to set up wit my wheel sizi i wanna insure my bag has full travel....thanks
in the tech section dev has a write up thats pretty good
devb22's avatar
devb22
Put the bracket as low as you can without sacrificing the 'bag laying out completely!
So basically crush the bag, as if you were laying it out...throw the 'bag in there and tack your brackets, and run it through the range of motion to ensure you get the best bang for your buck!
Dev <img src="{SMILIES_PATH}/icon_biggrin.gif" alt=":D" title="Very Happy" /><!-- s:D -->
speedster93b's avatar
speedster93b
possibly easier than that (IMO) is find out your bag spec's and put your a arms and spindle in the aired out position, and measure (best to make a mock up) up the frame from the lower control arm just enough to have the bag compressed when your suspension is at its limit. and using said mock up will ensure your upper bag plate is absolutely square with your lower arm.
speedster93b
sure making a mock up is an extra step and its worth it. i made a mock up for re6 and re7 slam bags and the f9000 sleeve bags. i'd say its definately worth the ten minutes it takes to make one even if you only use it twice. at least your bag will be right. then u can even use it again and again.
devb22's avatar
devb22
Def. an awesome way to do it!
I agree completely, doing a mock up is worth the time...
Dev
