Mazda Lowering Static \  torsion bar bolts
torsion bar bolts
views 2504
replies 14
following 9
89mazdawg(daniel)   +1y
can someone take a picture of the actual torsion bar bolts that i have to turn in order to lower the front? i just ordered my blocks and shocks, and just wanna make sure i am looking at the right bolt for when i go to lower it. thanks.
outkastdawg   +1y
it will be the bolt at the end of the bar that runs from your control to under your cab
low down89   +1y
i think you hit the nail on the head there
90-b22dawg [andrew]   +1y
its under the truck about mid door... and it requires a 17mm socket... also when doing the lowering remember to jack the truck up and put on stands (under the frame not the front suspension) other wise you run the risk of breaking the torsion bolts (which alot of people [including myself] have done because we didn't jack the truck up and put on jack stands) also if the bolt breaks the front end will then be sitting (depending on tire size) on either the tire (up against the top of the fender well) or the lower control arm will be sitting against the bump stop (which will ride like total poo) you could also (depending on your position if the bolt breaks) be crushed by the truck [may not flat'n you like a pancake but it will hurt like a mother bitch] .... "DON'T BE DUMB, BE SAFE!!"
sonikk71   +1y
Nooooooo it is a bolt not a nail!
low down89   +1y
I can't help it i'm from Tennessee, thats what everyone here uses for everything stupid rednecks.
93 2600i(zach)   +1y
please post a picture of the torsion bar, i lowered my read with blocks today and i have no clue where the bars are/ bolts
mr. b22   +1y
lol i guess people cant just say no we cant take pics or we dont have them....... if i go to the shop today and see my camera ill snap one for you.
mr. b22   +1y
mind posting a pic of your rear block set up?? i wanna see it, cuz im about to lower the rear end next weekend
im off to the shop to snap your pic, ill try and post it asap
toddluck   +1y
ill try to remember to snap a few after work
