Mazda Lowering Static \  lowering question
lowering question
views 1201
replies 15
following 9
89mazdawg(daniel)   +1y
well i got the rear end of my truck lowered earlier, it looks a lot better in my opinion. but i have a question. since i lowered it, when i'm going straight my steering wheel is crooked. is this normal?
racer x   +1y
nope.It should have changed since you lowered it.
anyone else?
lvnlo   +1y
thats not normal unless ur diff is not located properly and is on an angle causing ur ute to crab along...lol
check locating pins are in correct place and u bolts are tight
otherwise have u taken ur steering wheel off lately?
thebeaumartin   +1y
yeah the pins must not line up right causing this to happen. your thrust anhle is off take it back apart and make sore the pins line up
mk. tomorrow i'll take it all apart and take pictures to verify i did everything the right way.
toddluck   +1y
did you use angled blocks??
yeah i used angled blocks. i put the higher end in the back. i took everything apart today,and checked and everything lines up right. so idk why its still doing it. couldn't find the camera though so no pics.
bodied b2600zx (josh)   +1y
haha... crab along... nicely put, sorry to whore, that jus made me laugh
sonikk71   +1y
Ok no one has asked you this so I will....You do know what we mean when we talk about "the pins" right? And did you lower the front all? Cause if you lowered the front to match the back you will need to get an alignment.
