Mazda Lowering Static \  ? about flipping the ball joints...
views 983
replies 9
following 5
staticb2200   +1y
Both hole in the spindle and the ball joint it self is tapered. Now how does the inch and a half that your supposed to get out of this work. I did it and only got maybe a little more than an half inch. I couldnt totally flip the ball joint upside down because the taper on both the spindle and ball joint. I cut out the bump stops and and the hump in the lower control arm. Does anyone know something I dont? Thanks in advance fellas!
dropped90(justin)   +1y
i dont know where you heard youll get 1.5'' of drop from but you were lied to lol. usually gettin about 3/4" of drop from it and you dont actually flip anything you just take it from the bottom to the top.
-justin
thebeaumartin   +1y
yeah like droped90 said you just take the ball jont from under the c-arm and put in on top
toddluck   +1y
follow this write up
lowblownranger   +1y
yeah im the one that did that write up... the very first time i heard about flipping ball joints i though you literally fliped the ball joint... but no all your doing is moving the balljoint from under the control arm to on top the control arm
staticb2200   +1y
Well thats been done and thats about what i got was that 3/4". I have no complaints because it is low dont get me wrong, I went 3 notches on the tortions and flipped them. Thanks alot for the help guys.
staticb2200   +1y
one more question. How do i get the pic of my truck on with my posts? I have been trying to figure that one out with no luck. Thanks again.
staticb2200   +1y
O and also lol. I found that a 81-02 Nissan fronteer or 80-82 chevy Luv front shock is a very good shock for this setup (compress length= 8.000, full length= 11.75", total travel= 8.375)
lowblownranger   +1y
use photobucket and it will if you the image (whatever) and copy and paste that on here its all free so good luck
staticb2200   +1y
Here is the dawg b4 I flipped the ball joints
