Mazda Lowering Static \  torsion bars and leaf springs???
views 739
replies 5
89mazdawg(daniel)   +1y
ok. so first question, what exactly does re-indexing the torsion bars do? i already have mine cranked down, so could i re-index them to go lower up front? Next question, how exactly do you take a leaf spring out? Any pictures and information will help. Thanks Guys.
91b2200(cody)   +1y
well ya you crank them down then re-index them to even lower it more i think and then the rear is simple all you do is lift up box and remove leafs by taking bolts and u-joints out but its pretty easy .. maybe someone elsw can explain better ... but when you do the front you NEED to go get an alignment ..
toddluck   +1y
actually reindexing stiffens the front end up a lil bit and moves the bracket up so it doesnt drag it doesnt get you any lower
91b2200(cody)   +1y
ohh iam STUPID HA
toddluck   +1y
not at all
low down89   +1y
But once they are reindexed you can crank them down some more for a cheap drop but there will be some cutting off the bump stop brackets involved
