Mazda Lowering Static \  4 link???
4 link???
views 851
replies 7
following 5
3rdtimesacharm   +1y
how long of 4 link bars, upper and lower are evryone running?
hex0rz   +1y
Go no less than 20" bars.
3rdtimesacharm   +1y
does 29'' bottom and 31'' top sound right?
blackhulk   +1y
my bottom links are 31inchs
top are 29inch....i get smooth control through the motion
bodied b2600zx (josh)   +1y
Ya i thought the lowers should be longer than the top
3rdtimesacharm   +1y
thanks for the help guys. i was going to run both upper and lower to the same crossmember. is thay a bad idea? or should i run to upper to the frame and lower to the crossmember?
at dusk   +1y
mine are ran to the same crossmember the lowers on the bottom side, the uppers on the top but the uppers are triangulated so you need the longer bars up top..
Runnin em to the same crossmember is fine but you need to read up about instant center and understand that, that is the most important thing when settin up a 4 link, that and pinion angle
