Mazda Lowering Static \  Front Right Brake Dragging.
views 704
replies 2
atd   +1y
My front right brake has a slight drag, Ive replaced the ruber hose and brake caliper. I blew air through the steel line also to check for a clog there. All other brakes are fine. When brake is dragging the pedle has little to no play and is firm. However if i let it sit for a while say 30 min the brakes seem fine i can move the brake pedal a couple of inches (pedle feels normal) , there is some brake squel.
When i disconect the brake line from the right brake caliper the brake fluid will not drip out. I ve bled all brakes. 4-5 times allready. Could there be air in the system??
Im not sure what else to do. Maybe try a new master cylinder but i doubt it will solve the problem.
This also only occurs after driving for 5-10min or so and does not happen right away in the morning.
2 calipers and the same problem
im getting frustrated, i was sure it was a caliper too.
I have a 91 B2200
hocbj23   +1y
there is a proportioning valve on the firewall under the master cylinder.check and be sure one of those lines isnt kinked.bj
toddluck   +1y
depemds on the year of the truck your valve might be on the pass side fire wall
