Mazda Lowering Static \  Question About Wheel Alignment?
views 918
replies 1
following 2
framescraper   +1y
i dont know if you can anwser this question or not! i have an 88 mazda b2200 std cab, i had it bagged and stock floored bodydropped, my problem im having is when i drive the truck the wheel alignment is so out of whack i have to use both hands to keep the truck straight and really cant go over 35mph it just seems scary to drive if i let go of the wheel its all over the road, is there something i can do to the truck since you really cant get a wheel alignment on the truck! is there a camber kit or something i can do to get it to drive straight, let me know if you tell me what to do, thanks,
sean
layedoutb2k (chase)   +1y
they can still do a toe alignment at a shop. some shops wont touch it but you gotta look around. i was havin sorta the same problems on mine but i got an alignment done and it fixed it. you just need to make sure you get the alignment set while at the ride height that you normally drive the truck.
