Mazda Lowering Static \  lifting with torsns
lifting with torsns
views 654
replies 6
following 6
speed171king   +1y
my mom wants a lifted truck so she wants to trade my mazda for her civic and i was wondering how high i can get it with stock torsns also if i move the axel to the botom of the leafs how high will it rais thanks
dragn37   +1y
With the torsions cranked, ud probably only get a inch or two? i never raised a truck with torsions, only dropped
just my 0.2
lost_b2200   +1y
if you reindex the torsions, you can get good lift up front. flipping the rear will lift it a little less than 3" i think. but you could then shove blocks in there for more lift
fattirebicycles   +1y
flipping the rear would give you a lift equal to the thickness of the spring pack and the diameter of the axle tube.
speed171king   +1y
thanks alot but u guys think i can get it to level out or get the front alittle higher than the rear
ledevil   +1y
When I re-indexed my front keys I got almost 4 to 6 inches and after that I had started getting +chamber
EDIT: Not to mention it rode like a old Log Wagon REAL STIFF! Almost like rolling with no torsion bars and no bump stops
hex0rz   +1y
Lift it all the way and get it re-aligned. You'll probably wanna get some longer shocks afterwards though. Make sure you have some good rubber on there too as that can make a good difference in how you feel the road when they are a little underinflated.
