Mazda Lowering Static \  1990 MAZDA
1990 MAZDA
views 1334
replies 14
following 6
la mazdita 90   +1y
HEY I HAVE A 1990 MAZDA B2200 AND I WANTED TO KNOW HOW I CAN REMOVE THE - TORSION BAR- IF YOU CAN HELP ME, THANKS
slammed dimensions   +1y
why do you want to remove it?
la mazdita 90   +1y
I AM PUTTING HYDRAULICIS ON IT AND I WANT IT LOWERED ALL THE WAY DOWN.
big rick   +1y
Just unbolt the anchor bolt and slide the t-bar out of the splines. Its easy. Check out the write up on re-indexing your t- bars. Then you might want to flip your ball joints and notch your control arms. There are really good wite ups in the tech forums. Maybe someone can post a link?
big rick   +1y
toddluck   +1y
yup that how ya do
Raise and support vehicle. Remove wheel. Remove anchor arm bolt and anchor arm. Remove torsion bar.
la mazdita 90   +1y
WHAT IF I CUT THEM
If you cut them with ANY tension still on them you could hurt yourself.
big rick   +1y
I wouldn't recommmend it. There is a lot of force on those. Besides, It takes mabe ten minutes to unbolt them. It is only two bolts. Make sure you put the truck on jack stands though. The suspension should be UNLOADED before you take the bars out.
