Mazda Lowering Static \  how tight should the torsions be?
views 703
replies 6
danny death   +1y
hey guys i was cranking down the torsions this weekend and the drivers side was hella tight. it felt like i was gonna break the bolt. i made it 5 turns and stopped cause i didn't want to break that bolt. then i went to the passenger side and it turned down like a breeze. so i went back to the drivers side and got 7. the drivers side was taking pretty much all the effort i could give on a 1/2 drive ratchet (around 50-60ft lbs). and the passenger side took nothing at all. i want to go further but i thought i'd check to see if any one else has encountered this.
any ideas?
and yes i gave the bolts a shoot of moovit.
and the truck was off the ground on jack stands.
konzern1   +1y
they should come unbolt pretty easy if the front tires are off the ground, are u gonna just crank the torsions or re index the bar?
danny death   +1y
i was just gonna crank the torsions.
konzern1   +1y
ur only gonna be able to get so much out of that without the hook at the end being dangerously close to the ground
danny death   +1y
from what i got i look alright now, i was hoping to go maybe another half inch; making the total drop maybe 1 3/4". im not looking to go super low. i live on a dirt road. i was thinking about re-indexing not sure if i should...
sleepyspeed   +1y
re-index is the way to go. Mine is down 3 or 4 notches and I ran the tension bolts back to where they were stock. It rides like stock just lower and the brackets aren't on the ground.
91b2200(cody)   +1y
my drivers side was tight too but i sprayed it with lube and it was good .. then it was EASY!
