Mazda Lowering Static \  load sensor adjustment
views 741
replies 5
bryandamage   +1y
my rear brakes are locking up with i brake hard.
i think it's probably because i have blocks in the rear and it thinks it loaded up too much so the load sensing G valve is putting too much pressure on the back brakes.
i've looked in the manual and all it's got is how to test it to make sure it's not faulty.
doesn't say anything about adjusting it if your rocking a mad static drop
anyone had a similar problem? is it easily fixed?
(also, i know it's not really engine related but there's no braking board. Mods feel free to moved this)
low down89   +1y
hmm never had that problem but wanted to bump this up for ya good luck
h2omelon(nick)   +1y
Remove it and replace with a t fitting.
bryandamage   +1y
interesting idea H2o, have you done that? if so, do your brakes work fine or is it a sort of compromise fix?
like does it stop the brakes locking but cause something else, like not braking hard enough in the rear?
h2omelon(nick)   +1y
I've done it on a couple of trucks and never had any problems.
bryandamage   +1y
cool, thanks mate. i'll give it a go.
