Mazda Lowering Static \  Rearend prob's an Q's
views 500
replies 0
following 1
killerb   +1y
So the problem here is I've fubared another rearend(#3) an now I'm having a heck of a time finding another carier, which is all I really need. Now from what I've soaked up from here an looking around on the net the rear diff from 4x4 b-series an maybe the front will work(correct me if I'm wrong). And I think, not 100% sure without the parts in my possesion that a rear diff out of a Suzuki sidekick/tracker might work since they are 26 spline an 27mm dia. same as our trucks. I've also debated doing a 5 lug swap the only thing I have'nt found is what year yota's are the part's being pulled off of, an do they have to be 2wd or can 4wd pieces? Also what rearend are some of you guy's using with your 302, rotary swap or what you may have? BTW I'm not running the stock 2.2, I'm running a 87 rx7 13b t2, medium streetport, so maybe in the 2-210 hp range.
