Mazda Lowering Static \  Battery Dead after using Air Zenith!
views 508
replies 4
kirkpenneyfan   +1y
Alright so i got the back dropped monoleaf and 3inch block.
Bagged the front - 4 GC 350 Valves, 2 RE5 Slams, 9 Gallon Tank, Silver Air Zenith Compressor
Problem i am having is the battery went dead after in installed the compressor, using a multimeter all the valves, compressor, switchbox is grounded out...took the truck to autozone and the charging system checked out found out it was a bad battery. Didnt have this problem before the compressor was installed.
Question is could the compressor be bad? If so what compressor should i get now? i was looking at Viair 480 or possibly the new Viair 492 or 495
mazdawg(mikey)   +1y
your battery could already be on its way out and putting that extra pull on it killed what was left of it.
kirkpenneyfan   +1y
the battery was an optima red top which was built or put together or what ever it was in 09-08
mazdawg(mikey)   +1y
did you run the battery dead?
baggd   +1y
All I know is that if you decide to get different compressors a pair of 480s is what I've been running and they treat me very well, just a thought.
P.S. They are on sale at the BAG SHACK this month.
