Vibration at low speeds
jfrolang@hotmail.com's avatar
jfrolang's avatar
jfrolang
My whole truck shakes between speeds of 25 and 35 or so mph. I know I have one bad engine mount, but I don't believe the problem is RPM related, since I can be coasting to a red light and kill the engine, and the shaking doesn't stop. Revving the engine while stopped is completely smooth. I ordered new upper and lower ball joints, a new idler arm and pitman arm, that stuff is supposed to arrive on Tuesday. I'm hoping that stuff helps when I get it in, but am I looking at something more serious? The front tires show cupping. I don't think it's wheel bearings, I've dealt with those before, but only on FWD Hondas.
mazdatweaker
post deleted
Post was last edited on May 13, 2009 12:59. Edited 1 time.
jfrolang's avatar
jfrolang
That doesn't help me, I'm not new to vehicle maintenance. What you're missing is that cupping on the tires indicates worn suspension components. What I'm asking (in a nutshell) is if this shaking is a common result of any of the worn items that I will soon be replacing, or if it's something more. I guess I'll just have to find out after I put the new parts on and have it aligned.
lowered_impressions
Balance your wheels!
jester's avatar
jester
Check your driveshaft u-joints. Mine did the same vibration at low speeds then eventually got worse, stupid me replaced the whole front end before I figured out the problem. Lol
speedster93b's avatar
speedster93b
shocks!!!!
mazdatweaker
post deleted
Post was last edited on May 13, 2009 01:00. Edited 1 time.
royceta59's avatar
royceta59
like he said u joints or possibly your pinion angle could be tweaked and youre getting diff hop??
