Alignment specs
mazdaspeed_gotrice@yahoo.com's avatar
Alignment specs
killerb's avatar
killerb
I'm curious if anyone knows or has alignment specs for our trucks? What have some of you guys done for a alignment especially since some of us are bagged. Nobody around here has the stones to try or bother touch a dropped vehicle weather its a static, coilover, bag or juice. So I'm trying to find some info on doing this myself.
killerb's avatar
killerb
Also what would cause it to be hard to steer to the left only?
speedster93b's avatar
speedster93b
your alignment shop will be able to give you stock specs.
as for what might cause it to be hard to steer to the left? what have you done to your truck already? i'm assuming your bagged... is it hard all the time or just sometimes? (certain heights...?) have a buddy turn your steering wheel and you look under the truck if you can and check out all possible linkages, strut rod, control arms, pitman arm... everything. check your castle nuts and make sure they're tight and have cotter pins in them. tie rods too...
