Mazda Lowering Static \  help finding rotors
help finding rotors
views 637
replies 5
blaz4wd   +1y
Here's what I have,,
I have the mazda hubs that have been redrilled for the ford ranger bolt pattern. what i need to know is what rotors i have to run or do i have to get my mazda rotors drilled out for the ranger??? Thankz for you help in advance Joe
plumbous blimp   +1y
you'd probably have to get your mazda rotors drilled to the same bolt pattern, which opens a whole can of worms. but i've never done that mod before, so i'm just guessing.
mazdalowandslow   +1y
Well sense Mazda rotors aren't mounted to the front of the hub you shouldn't have to get any special hubs. I had my Mazda hubs re-drilled and the stock rotors work fine
mazdalowandslow   +1y
This is as long as you have a 86 to 93 Mazda pickup.
elbine69   +1y
Redrilling the hubs has no effect on the rotors so the stock ones will be fine.
blaz4wd   +1y
so If i would look b4 i ask do these rotors bolt to the hubs and not like you chevy stuff where they held on by the lugs.
