Mazda Lowering Static \  cutting bed help
cutting bed help
views 832
replies 6
amgine_   +1y
im planning on bagging my truck soon.. i was wondering how i could bag the back without cutting the bed and how low it would be????? how about mini notches?? pics anyone??? i might bag it on 15in pathfinders or 18in ziniks
blackhulk   +1y
mini notches or u can use 3-5 round stock pipe and cut it into two half's and cut ur frame and mount them in there but leave a some meat on the frame for structure but ur shocks will have to be a mad angle for them to compress and lengthen ...that should get u goin
blackhulk   +1y
in this link u can see were the bag and shock are..u can use it as a reference point for u to understand it better he has a two link with pan hard bar bags on outside of frame rail
hope that helps ya
amgine_   +1y
what about bag over leaf???
blackhulk   +1y
its not with the problems..i seen guys do one leaf but in the end u have ONE leaf holding each side of ur machine if they break it anit a pretty site..a single leaf is weak...ppl still have them but its iffy..ur better off in the long run to use some link system
devsmazduh   +1y
if you do 15 inch pathfinders. just mini-notch the bitch. just like 3 inches. thats what i did. and my frame is 2 inches off the ground in the rear and lays in the front
mazdawg(mikey)   +1y
had a good friend that ran a pipe notch like hulk said. he also ran a piece of 1 inch stock on top of the frame to give it some more strength. he had a mono leaf setup with air shocks and it would lay out on 16in 300zx wheels with adapters.
