Mazda Lowering Static \  wobble problems
wobble problems
views 1103
replies 9
following 7
kenny_no-meat   +1y
i just brought out the mazda and when i when to drive on the high way it started a real bad wobble bad enough i all most lost it so im not new to minis but new to bagged minis w.t.f. any tips i was told could be the 4 link set up
tuckin20s   +1y
So I am taking it that since you think it is the 4 link, that the wabble is in the back? If it has been sitting for a long while the tires could have flat spots on them but I don't think it would make it wabble that bad. Tires out of balance? Any bolts loose? Wheel lugs? Just trying to run down some Ideas. I would lean toward a wheel or wheels being out of balance! Good luck and I hope this helps a little.
91extcab   +1y
bent axle in the rear? ive got that problem on my pass side rear tire... slightly bent axle... slight wobble... i also had loose lugs on both rear tires a while back and they wobbled bad enough that i have shiny rub spots on the inside of the bed fender wells...
kenny_no-meat   +1y
i have no ideia where the wobbles at somebody suggested the 4 links i know it was f'n horrible scared me so bad i started sweatin what all should i check
korrupt1   +1y
if it was you 4 link and the axle would swaying especially when shifting...I had that but I had loose ubolts...tightened up and all was good. check everything especially if it been sitting....
h2omelon(nick)   +1y
Is your 4 link forward or a reverse 4 link? We need a little more info on your setup and pics if possible.Also are you running shocks in the rear?
kenny_no-meat   +1y
i have two forward and two backward,i was told they all needed to be one way
nc4life   +1y
This wobble you have do you feel it in your steering wheel, if so does the steering wheel shake really bad or feel like its turning left to right? Does it happen while driving regular or hitting any kind of bump? About what speed does it happen at? Do you have stick if so does it do it when your changing gears hard? Also check all your bolts.
91extcab   +1y
i had issues a while back with the back end swaying back and forth... was the diff rocking back and forth when stepping on or letting off the gas... had loose U bolts...
68sweet-n-low   +1y
you said your 4 link was two forward and to back ward like on the opsite side of the rear end, you have to get sum pics of that plus if could be a little bit of every thing like bent rim, tires, loose bolts any where on it. just get us sum pics and such and give sum more details and we will help as much as posible
