Mazda Lowering Static \  Valves
Valves
views 798
replies 7
following 5
mazdadropped   +1y
Hey i want to change up my set up and get 8 valves instead of 4 so i can have side to side
but i want the smallest airline possible do they make 1/8" valves the lowest ive seen is 1/4" and if i run 1/4" i was thinking of making 1 air line split of into two and feed the rear bags and another line spliting into two and feeding the front bags jsut to slow it down a bit cuz the body drop
devb22   +1y
1/4" is the smallest valve they make for use in your application...
FYI: They make valve flow controllers!!!
immortal1 (linn)   +1y
^ got a set of flow controllers on my daughters truck (1/2" valves). They work great! Can be set for a VERY slow drop if you so choose.
mazdadropped   +1y
i thought about using those but i dont want to
toddluck   +1y
my 84 has 1/4 line works smooth but im going 1/2 up 1/4 down
mazdadropped   +1y
Ok i made my decision im going 1/4" but im still unsure with the fittings i know not to get plastic or brass but is there a kit for 1/4" fittings im not to sure what fittings would work
i know i want two "t" fittings so the airline can be split into two for the front and rear bags any help will be appreciated
mazdadropped   +1y
I Think Cando Specialties Looks Like The Place To Get Em
bodied b2600zx (josh)   +1y
thebagshack.net carries fittings too. . .
And on my old s10, I have put reducer bishings in the dup valves to make to holes smaller. . they worked great. . helped alot. .
-Josh
