Mazda Lowering Static \  Got a Few q's
Got a Few q's
views 842
replies 5
bk2minis   +1y
What would be the best bags to run for a stiff ride?
I don
bk2minis   +1y
!Somebody..... something....... anything..........
noridetoolow   +1y
Air ride makes kits for actual performace and handling.. like the strut bags. Standard air bags typically do not equal good handling. I am on my fourth bagged truck and not one has handled ANYTHING like any non-bagged vehicle. # of vales, size of bags....nothing seemed to really make much difference. Full size and mini alike. But.....if you can squeeze 2600 bags up front and fun a good stiff shock, you will probably do alright. It seems to work best running seperate vavles to each bag....so even though you dont want FBSS the setup will give you less body roll in corners.
If you go the route of strut bags ( which is probably going to be your best handling air ride setup ) then you might even wanna consider a Toyo front clip with standard upper and lower A arms.....really you can do anything though....fabrication has little in the way of limits.
All that said....I am making the assumtion that what Air Ride Tech makes for a late model Camaro will perform as much as it can in a similar fasion on your mini
GL
bk2minis   +1y
I kind of leaning towards keeping the stock front clip. thanks for your in put though it is truly appreciated. If I go changing front clips I'll look in to a mustang two front end to get multiple brake options and rack-n-pinion steering.
Also I was told that the smaller the bag the More psi it takes to lift, so that would mean a higher spring rating. "in theory".
I may look in to those strut bags though?????
Or just go for the old slush ride.
This bag stuff is seeming more and more discouraging, I know its not going to handle like my IS but I would like it to handle atleast a little better than stock
korrupt1   +1y
If they can make those things handle....then why not a truck?
Would you have to be a bit creative? But isnt that truck creation in the first place?
This is something i have been looking into myself
beatmymini   +1y
I want some of those!!! that would be sweet.
