Mazda Lowering Static \  evening it out.
evening it out.
views 1590
replies 18
following 7
bee.em.doubleyou   +1y
i have an 87 b2200
and i ripped out the torsion bars.
and took out 2 leafs in the rear and added a three inch block.
but the rear is still higher than the front just a little. enough to just throw it off.
how can i even it out???
hocbj23   +1y
4 concrete blocks oughtta do it.bj
minituckin   +1y
Put your Torsions back in and crank/reindex them untill it has an even stance
bigamigo   +1y
park on a hill
but i like the heighth of the front and would rather find a way to get the rear lower rather than the front higher. and parking on a hill is doing the trick!
91b2200(cody)   +1y
if your frame is on the axle then spend the money and get a notch kit..
then you can go with bigger block or whatever..
My friend just bought a b2200 and hes as low as he can go without a notch.
and all he did was flip the stock leaf springs. and it put it all the way down.
flip the stock leaf springs?
know where a write up on that is?
90-b22dawg [andrew]   +1y
speed kills....
sorry dude, i'm just new to this. i'm used to buying a set of koni yellows. and some groud force coilovers and calling it good. never done a truck before. so i'm still learning.
removing the torsions isn't a very smart idea.... you can reindex them and cut out the bump stops and still sit very low... as for the rear you can notch it and mono leaf it but you will need some angled blocks to help with the pinion angle....
